Ignition Key stuck in ignition HELP
Old Mar 30, 2019 | 05:28 PM
TinPhx's Avatar
Default Ignition Key stuck in ignition HELP
I can’t get the ignition key out of the ignition with the switch in the proper position to remove it.
Tried jiggling and wiggling and some 3in1 oil. Need help I can’t secure my car!
Thanks in advance for your time and help!
Old May 10, 2019 | 01:46 PM
Gforce junky's Avatar
If you can pull the key out in a different position then do so and use something else to move it back to the lock position like a screwdriver. (gently) It has should lock without the key.
I would suggest replacing the ignition or having it repaired.
Old May 10, 2019 | 10:56 PM
TinPhx's Avatar
Default Thank you I appreciate your time and help...
I was able to get it out after playing around with the shift interlock
Akorpal
Jan 7, 2018 03:30 PM
berekdinda
Jan 28, 2016 05:34 AM
Dannyboy8119
Jul 21, 2015 02:57 PM
formana
Feb 7, 2011 05:39 PM
Dana
Oct 18, 2010 11:38 PM
