Ignition Key stuck in ignition HELP
I can’t get the ignition key out of the ignition with the switch in the proper position to remove it.
Tried jiggling and wiggling and some 3in1 oil. Need help I can’t secure my car! Thanks in advance for your time and help! |
If you can pull the key out in a different position then do so and use something else to move it back to the lock position like a screwdriver. (gently) It has should lock without the key.
I would suggest replacing the ignition or having it repaired. |
Thank you I appreciate your time and help...
I was able to get it out after playing around with the shift interlock
Originally Posted by Gforce junky
(Post 88342)
