Whistling Noise
Old Dec 19, 2007 | 02:57 PM
Johnnymo's Avatar
Two months ago a whistling noise developed fairly quickly and hasn't changed since. It seems to be a loud whistling noise however I suppose it could be a bearing of some sort. The noise does not change if I remove the serpentine belt nor does it seem to be a function of rpm's. It remains the same regardless if I am in gear or neutral and clutch in or out. As best I can diagnose I think that it coming from the back of the engine. I thought that it might have something to do w/ the EGR valve/system but cleaning that (and the valve was stuck) didn't make a difference. In fact while runing the enging w/ the valve removed made no difference as well. Any thoughts?
_uacct = "UA-939292-44";
Old Dec 19, 2007 | 08:23 PM
Sounds like a broken intake manifold gasket. Dont know what year yours is but its somewhat common on '98+ rodeos.
More info http://isuzufaq.ibctech.ca/#faq5
Edited by: Gizmo42
Old Dec 19, 2007 | 08:29 PM
Johnnymo's Avatar
.Edited by: Johnnymo
Old Dec 19, 2007 | 08:32 PM
Johnnymo's Avatar
Sorry for omitting these details:
1998 3.2L 195K miles
Also and maybe related: Upon start up when the engine is cold, it sounds like your in the middle of a tornado...well perhaps not that extreme but a very very loud windy noise. Then after as much as a minute, the sound suddenly and instantly goes away never to be heard again until the engine totally cools.
Old Dec 20, 2007 | 10:45 AM
That is most likely just the cooling fan. Its normal. When everything is cold and you first start it the fan clutch will be locked up. It soon releases and starts working. My mitusbishi worked the same way.
Old Dec 20, 2007 | 05:34 PM
daisysride's Avatar
Thats just your intake!!!!!! nothing to worry about that's the best thing to hear COLD AIR!!!!!
daisysride &lt; src="http://www.google-analytics.com/urchin.js" =text/&gt; </>&lt; =text/&gt; _uacct = "UA-939292-44"; urchinTracker(); </>
</>Edited by: daisysride
Old May 17, 2008 | 01:02 AM
Nick6147's Avatar
Yeah its an air leak. Shouldnt be a problem at all. Just as long as the engine stays cool.
Old Jun 2, 2008 | 05:05 PM
  #8
rock's Avatar
Has your problem been fixed?
mcputman917
Nov 21, 2006 09:41 PM
c4chris
Jul 24, 2006 04:09 AM
DEEBEE
Mar 28, 2006 11:03 AM
benson662
Jul 22, 2005 01:39 PM
blurex7
May 27, 2005 02:06 PM
