egr valve/tranny ?
Old Jan 2, 2006 | 05:13 PM
mewatts's Avatar
so i have a 98 rodeo and have a problem or two i need help with. 1st, my check engine light comes off and on all the time. the code always says its the egr valve but ive already replaced that and cleaned it. problem #2 is my tranny. i had it rebuilt about a year and a half ago but now, on occasion, when i start it i cant push the button on the shifter to put it into gear. is that even a tranny problem or could it be something else. yes, i am pushing the brake pedal when trying to put it into gear(my husband had the nerve to ask) anyone have any ideas!!!
Old Jan 3, 2006 | 04:59 PM
ISUZUGURU's Avatar
Super Moderator
how did you clean it,to properly clean it on that yr you need to remove the t-body,an you,ll see a tube right in ft,its proably clogged.thats why it keep setting the code.an you dont have a trans problem. the shift interlock cable is mis adjusted.this is how an why you suppose to step on the brake to shift out of park,you may even need a new shifter asssembly if it cant be adjusted.if there,s spill drinks ,ciggerate ashes any kinda dirt,can harm this adj,take it to your dealer,theres a service bulletin they use to dothat adj procedure,any other shop wont know what to do.
greggd1959
Dec 20, 2012 05:36 AM
HybridFire
Mar 21, 2009 11:06 AM
Charlie
Dec 8, 2008 08:33 PM
gibsaenz
Mar 30, 2008 02:46 PM
Aquaholic
Apr 20, 2006 01:13 PM
