new guy
Old Aug 23, 2009 | 10:09 PM
cheapdad's Avatar
Red face new guy
New guy here--I'm Cheapdad, Eagle Idaho.
and, as of this afternoon, the owner of a 1994 Trooper-AT/6 cyl.
She will be shared between myself, and one of the "Cheapdaughters" (far from it!)
160,000 miles, good shape, new timing belt and water pump in last 2000 miles. Starts right up, no smoke, Trans seems good, Body has a couple of minor dings.
So--she needs tires...Geolanders from Tires Warehouse? What is best oil? recommended service times? helpful hints??? What does a new guy need to know?
...It's great being the new guy!
Cheapdad
Old Aug 24, 2009 | 01:09 PM
Cracker's Avatar
i suggest some high milage oil. or 5W30. my mechanic put that stuff in my truck, runs like a dream.
get her checked every 2000 miles, just a quick fluid check, oil, trans, rad fluid, etc etc.
if shes a daily driver, stick on some 295's any brand will do. if your going to wheel it, and bring her in the bush, maybe some 31's or 32's
avoid putting anything higher than mid-grade fuel in your truck, you'll burn out the valves.
other than that, just keep up with the regular maintenance, and she will last you forever.
Once a Trooper driver, Always a Trooper driver.
Old Aug 31, 2009 | 09:28 PM
naterover's Avatar
how does premium fuel burn valves? im not arguing, just curious.
Old Sep 2, 2009 | 12:42 AM
Cracker's Avatar
If your vehicle has high mileage, and the valves havent been replaced, if you put in a high octane gasoline, you're going to leave burn particles on your valves, and then gum up your fuel system
mattsworktwo
Oct 17, 2012 10:14 PM
Wolfcri
Apr 1, 2009 05:41 PM
ss045
Apr 6, 2007 10:29 PM
lashby
Sep 13, 2006 02:27 PM
deputylightning
Mar 6, 2006 05:33 AM
