Tail Light Prob.
Old Sep 3, 2006 | 04:12 PM
PrinceJeremie's Avatar
It starts everytime it rains a lot (It rained for three days straight here) When I switch to turn right or left, both of the lights come on...any quick fixes? I fixed it before by myself, this is the third time and I can't find a problem... I think it may be the switch [img]smileys/smiley11.gif[/img]
---I have a 1998 Rodeo V6Edited by: PrinceJeremie
Old Nov 14, 2006 | 10:02 PM
nate783's Avatar
i would try to find the flasher unit, it looks very similar to a relay but it is what pulses you lights and it will act up if condensation gets into it, it is more than likely under the dash, you should be able to hear it click when your blinkers are on, also do your hazard lights work ok?? because if they are messed up as well you may have a wiring issue, i would trace the wiring from the taillights anyways just to make sure there isnt any shorts or bare wires anywhere, hope that helps you!!Edited by: nate783
bwtr
Axiom
Dec 27, 2008 07:20 PM
ricebw2
Dec 20, 2008 02:19 PM
jstar41
Nov 11, 2008 11:23 PM
picinisco
Nov 1, 2007 04:58 PM
buckmaster 700
Feb 15, 2006 05:57 PM
