HELP! ‘96 Trooper
Old Mar 10, 2018 | 02:08 PM
MrMopar's Avatar
Default HELP! ‘96 Trooper
HELP!
My son’s ‘96 3.2 Trooper all of a sudden died out when he came to a stop light. I changed the plugs, was a little better. Then started dying while driving. Always starts right back up. No codes. No misfire, no stumble, just cuts out. I’ve replaced:
Plugs, fuel filter, fuel regulator, MAP sensor, IAC, crank sensor. Cleaned EGR, Throttle body, MAF. Inspected routing and condition of all the vacuum hoses. Checked the entire engine loom for cracks/breaks in the wiring. All good. Changed fuel pump relay. Good voltage and readings on O2 sensors.
Everything that I did seems a little better...starts right up, will run for about 1-3 minutes then die. No codes. It’s going on a month now and I’m stumped.
Oh and he’s had it since beginning of June last year, and it ran fine without doing anything to it. 150k miles
techNic
Jan 26, 2007 10:31 PM
bobbyl1989
Dec 21, 2006 07:10 PM
trooper90
Dec 1, 2006 04:49 PM
RDL888
Aug 28, 2006 05:50 AM
qha000
Aug 24, 2006 04:43 AM
