Getting Engine to Turn
Have a 1987 trooper that has been sitting for seven years. How would you proceed in getting it to turn? Connected battery and will not turn. Any thoughts on getting started on a rebuild?
I am assuming that you have tried to turn it with a socket and breaker bar
on the big nut on the end of the crankshaft. That done remove the spark plugs and pump liquid wrench and marvel mystery oil into all cylinders and walk away come back every day and try the breaker bar and add more oil keep it up until it starts to move. Switch to a ratchet and roll it over through several revolutions. When it's turning freely load it up with oil and out a 1/2" impact wrench on it and spin it over with that for a while. If you want to you could try putting the plugs in and see if it will fire up and run you might get lucky. If not, you were planning on a rebuild anyway.
