Check Engine Light Again
Old Oct 12, 2007 | 11:04 AM
Dennis's Avatar
May not be a new subject, but I am sure a sore one for us Amigo owners. Engine light issues are not new. The check engine light has gone on when the fuel got to about a 1/4 of tank (after the low fuel light flashed, the fuel gauge went to empty then back up) and the end result was an engine light which stayed on untill I filled up and it eventually went away. That was then. Now the check engine light has stayed on and will not go away. Any body have solutions for the check engine lightissues. Any help would be appreciated.
Thank You
Old Oct 17, 2007 | 10:42 PM
s10lowrider's Avatar
i would try to reaset the ecu, there are two single plugs plug them in for 5 min turn ur amigo off then unplug them, they are located next to the ecu, drivers side look down near your feet,
Old Oct 18, 2007 | 09:33 AM
Dennis's Avatar
Thanks, I will give it a try and let you know.
Old Dec 8, 2007 | 01:37 PM
pacman's Avatar
Hello,
Just checking in. Did this reset work? I think I've got the same problem.
_uacct = "UA-939292-44";
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
ish
IF Help & Suggestion Center
Jun 13, 2013 06:42 AM
sammie white
Sep 29, 2011 10:50 AM
collyswamper
Mar 22, 2008 11:27 AM
vamootsman
Mar 14, 2007 12:26 PM
gimmneycricket
Mar 11, 2007 10:39 PM
