Transmision light and Engine light
Old Sep 19, 2012 | 09:55 AM
ish's Avatar
ish
Default Transmision light and Engine light
Hello, I have an Isuzu Amigo 2000 I need some help. Got the transm light blinking and the engine light on.......about 1 yr ago had problems with the tramsmision....any suggestion what can it be? Thns
Old Oct 6, 2012 | 05:13 AM
berekdinda's Avatar
yes misting the wires includes misting the coil pack.
There was no evidence of any arcing of the coil pack...the plug wires showed some arcing. I'm going to change the plugs, and run some sea foam through it today.
locksmith nyc
Old Jun 13, 2013 | 06:42 AM
simonjames's Avatar
Most transmission-related noise happen at transition speeds. It happens during acceleration or deceleration in most cases, and idling in bad ones. The power works out the difficulty. It could be anything from a low allowance of lubrication to chipped gears.
mrdennisg
Jun 2, 2013 02:19 PM
sammie white
Sep 29, 2011 10:50 AM
yhata
Jun 5, 2010 03:23 PM
collyswamper
Mar 22, 2008 11:27 AM
derek44
Nov 25, 2006 03:38 AM
