Trooper exhaust
Old Jan 6, 2008 | 04:15 PM
jnelson's Avatar
I have a 1994 Trooper with exhaust leak from flexible joint in the front pipe. This is on the right side, second pipe coming from exhaust manifold. Can I just take out this flex piece and weld in a straight piece? Why is there a flexible piece there in the first place? If I can't just pipe it where can I buy a new piece? I have been looking all over and it seems that nobody has any parts from the cat forward.
Thanks
Old Jan 7, 2008 | 11:08 AM
atfdmike's Avatar
Hi, I don't see why you could not use a piece of flex pipe, although I would recommend using the stainless type rather than the aluminized steel. I recently had the same leak on mine, and I went to a junkyard and found a similar sized pipe/flex joint that I cut out of a wreck to use on mine. Seems like it was around a 2 inch diameter piece that I mig welded in.
Good luck.
_uacct = "UA-939292-44";
Old Jan 7, 2008 | 11:10 AM
atfdmike's Avatar
sorry, repostEdited by: atfdmike
Sparksend
Jun 26, 2012 07:44 PM
Mstalbaum
Jan 25, 2010 07:26 PM
bulvai
Sep 29, 2009 03:31 PM
smworth
Jan 18, 2009 02:56 PM
erikscorcia
Jan 8, 2008 01:16 PM
