lifters
Old Jan 30, 2007 | 10:54 PM
jwn1984's Avatar
My lil bro has a 96 trooper that has a lifter tap....what I am wanting to know is are they ajustable or not.... if not what should I do to help him fix this?
Old Feb 2, 2007 | 08:56 PM
MASTERTECH's Avatar
no they are not adjustable, the problem is the lifter oil hole are small and tend to get a varnish on the inside the only to properly fix it is to replace the rocker arms and the shafts, the rocker arms have the lifters in them, the only other way which you can try is to use 5w40 rotella diesel oil, it has a large amount of detergents in it and can clean some of the varnish up, if it were mine I would use the oil first because the parts to fix are high in cost.
Old Feb 4, 2007 | 12:13 AM
ISUZUGURU's Avatar
Super Moderator
i,ve never tried 5w40 mastertech......that would be a good idea ,forgot all about rottella T .myself an the guys at the dealer used 0w20.sometimes it works sometimes not,guess it depends on how worn the valvetrain is.lucas oil treatment does pretty good also
Old Feb 15, 2007 | 08:47 PM
atfdmike's Avatar
Isuzu service says that 0w30 mobil 1 is thin enough to clean and lubricate the lifters and oil passages. I think on an older engine the Rotella is a good idea AFTER trying a lighter oil and CD2, Rislone or similar engine cleaner. I worry a little about lubrication, especially when cold, with the heavy oil and dirty lifters.
88SuperTrooper
May 16, 2008 10:19 PM
marc9976
Apr 30, 2008 09:18 AM
Azathoth
Jan 5, 2008 12:22 PM
bbusbee
Apr 1, 2007 06:15 PM
sandyb23
Nov 11, 2005 04:16 PM
