Isuzu Trooper problem please help!!!
Old Jan 20, 2010 | 03:22 AM
phantom's Avatar
Default Isuzu Trooper problem please help!!!
hey i have a Isuzu Trooper 1990 it started over heating as i go up hills.. ive had the radiator flushed by a pro and he said there is good flow..the fans are all good and working... also i have redone the whole head.. everything is on and not leaking.. I am so puzzled? has anyone had this same problem before this before
Old Jan 25, 2010 | 05:51 PM
Mr. Movida's Avatar
Default typical for my 2.8 too
phantom
My '91 2.8l will do this too although it usually does not blow the cap or steam or spit coolant but stays just below these fun activities. Main problem is that this thins your oil and oil pressure drops (at least this has been my experience). My mechanic buddies (they used to run the Baja 500 in the good ol' days) says just slow down, dump a gear, up the RPMs and give up trying for speed for cooler running and you should be okay. I drive the mountain roads around here in So Oregon and this works fine, just don't let your Trooper get mistaken for a VW minibus...
Relax, slow down and enjoy the scenery.
Mr. Movida
  • "Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything." - former CBS News Anchor Charles Kuralt
chacachaca13
Dec 22, 2012 03:19 PM
khgmgw29
Oct 18, 2010 07:53 PM
cfont
Apr 19, 2010 01:10 PM
jere82
Feb 29, 2008 08:24 PM
trooper90
Dec 1, 2006 04:49 PM
