How to clean fuel injectors on my 96 3.2
Old Jun 8, 2020 | 04:39 AM
Tom Botts's Avatar
Default How to clean fuel injectors on my 96 3.2
I'm not getting fule to one of my cylinders on bank 1. Do I need to take the intake off?
Old Jul 16, 2020 | 07:40 AM
sdowney717's Avatar
I once did this on my 94 Buick. Pulled the injectors and soaked in 90% rubbing alcohol. Then I used a 12v battery charger to open each injector electrically, and using a childs round nose bulb, forced alcohol thru them both ways. there is a tiny screen filter in the input fuel side of each injector, which might be clogged. If the injector clicks open with the battery charger, you have a good chance of clearing the clog. Using the bulb you can generate enough flow to see the alcohol stream out of each port hole , like probably 6 of them on the output side. My problem was really old bad gas and a failed open fuel filter that let all the dirty crap into the injectors and they all clogged up.
machielr
Jun 27, 2021 11:57 PM
slipstick
Mar 10, 2010 12:23 PM
D Kill B
Feb 16, 2007 04:45 AM
Spud
Mar 3, 2006 08:32 PM
helpamom
Sep 27, 2005 07:28 PM
