died while driving.. and won't start back up
Old Apr 14, 2009 | 07:27 PM
jakerhoades89's Avatar
Unhappy died while driving.. and won't start back up
I have a 1994 trooper LS. 3.2L. DOCH. I recently changed the belts on the truck and topped it off with new fluids ect. Started and ran perfectly. Soon after, i was driving down the street and the truck cut off. So i figured one of the belts that i had just put on it broke. Negative. Now the truck wont start back up. After checking the belts, i checked the fuel. Fuel pump works fine and when i dissconnected the line it shot gas up to the front tire. Getting plently of gas through the filter. Also checked for spark and all plugs give off spark. No fuses were blown either. I have no clue why it just cut out and wont start back up. Please help me with any suggestions.
Old May 5, 2009 | 11:10 AM
Troop94WI's Avatar
Check your air intakes and throttle body for cleanliness.
Also the front ignition interface..more or less the electronic
distributor can have moisture problems. Inspect your plugs for
soot or exessive fuel build up from bad 02 sensor unit.
Make sure your plugwires are good.
Old May 5, 2009 | 11:50 AM
it turned out to be a broken timing belt.
Old Jun 1, 2009 | 02:24 AM
cocosan's Avatar
Check your new york escorts air intakes and throttle body for cleanliness.
Also the front ignition new york asian escort interface..more or less the electronic
soot or exessive new york escort fuel build up from bad 02 sensor unit.
Make sure your new york asian escorts plugwires are good.
Old Jun 12, 2009 | 05:05 AM
samabhi125's Avatar
I was also facing the same problem in my Isuzu Rodeo.
fendlay
Axiom
Aug 13, 2013 01:08 AM
ajwaldrop
Mar 20, 2012 08:19 PM
99Trooper804
Mar 31, 2011 01:04 PM
pharmakon
Nov 30, 2008 04:53 AM
snake0ape
IF Help & Suggestion Center
5
Dec 12, 2007 11:09 PM
