Brakes
Old Dec 16, 2005 | 11:11 PM
85supertrooper's Avatar
Ok I replaced the calipers,power booster, front lines and master cyc. Then bleed the heck out of the system.But heres the problem i still dont get much pressure with it off and when i turn the troop on i get no pressure. Pedal goes to the floor. I was wondering if i missed something or somewhere to start.
Old Dec 22, 2005 | 02:38 PM
Patrick's Avatar
Super Moderator
have you inspected the rear lines/braking assemblies?
Old Jan 18, 2006 | 11:27 PM
lowtrooper's Avatar
when you change brake lines you have to do a lot of brake bleeding in a systematic order. You should get the following: a haynes trooper manual and a suction pump brake bleeder(helps alot in the brake bleeding)
wentfarther
Feb 24, 2010 04:42 PM
gomez213
Oct 12, 2006 05:54 PM
rolando
Oct 1, 2006 06:07 AM
jenko
Dec 4, 2005 06:41 PM
furball
Mar 26, 2005 01:34 AM
