97 trooper engine ticking
Old Mar 21, 2005 | 01:20 PM
gforce's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
neet to find out if their is any thing i can do about the loud ticking my
troop do when it is first turn on in the morning...
i do keep the oil changed regurally and the maintenance up petty good.
Old Oct 11, 2005 | 01:12 AM
sailor285's Avatar
have you tried an additive called seafoam?
Old Nov 20, 2005 | 01:19 PM
lowtrooper's Avatar
Hey man that seems to be a prob with the valves. you should take your troop to a mechanic to check them out. Most probably its therocker adjustment that it's too loose.
Old Jan 2, 2006 | 05:05 PM
davidteachey's Avatar
It's the rockers in the valvetrain. Once good, viscous oil gets to them, they quiet down. My '94 Trooper 3.0L did that, and my current '96 Trooper 3.2L does it. I suspect an inherent design flaw. I've learned to live with it, and of course, I stay very current on oil changes! Cheers,
David
Old Jan 15, 2006 | 06:22 PM
csantac's Avatar
i have a 2001 trooper with 63k,the engine has just started to tick when
you give it the gas , help! does anyone have an idea what it is and
what i can do to fix? tks, chris
Old Jan 18, 2006 | 11:17 PM
lowtrooper's Avatar
Originally Posted by gforce
&lt; =&gt; <!--
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
//--></>neet to find out if their is any thing i can do about the loud ticking my
your problem could also be the engine timing or a faulty exhaust gasket.
Old Mar 3, 2006 | 07:43 PM
surpera1's Avatar
change your oil and add1 lucas oil treatment.also change your filter to a purolator.worked for me.whatever you do dont use a fram filter.worst on the market.
trooper95
Jan 23, 2016 07:56 AM
thatdude95
Nov 10, 2014 12:48 PM
shawnferg23
Nov 2, 2008 05:02 PM
Aquaholic
Apr 20, 2006 01:13 PM
dabeef7
Mar 4, 2006 05:11 PM
