< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> neet to find out if their is any thing i can do about the loud ticking my troop do when it is first turn on in the morning... i do keep the oil changed regurally and the maintenance up petty good. |
have you tried an additive called seafoam?
Hey man that seems to be a prob with the valves. you should take your troop to a mechanic to check them out. Most probably its therocker adjustment that it's too loose.
It's the rockers in the valvetrain. Once good, viscous oil gets to them, they quiet down. My '94 Trooper 3.0L did that, and my current '96 Trooper 3.2L does it. I suspect an inherent design flaw. I've learned to live with it, and of course, I stay very current on oil changes! Cheers, David |
i have a 2001 trooper with 63k,the engine has just started to tick when
you give it the gas , help! does anyone have an idea what it is and what i can do to fix? tks, chris |
Originally Posted by gforce
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--></>neet to find out if their is any thing i can do about the loud ticking my troop do when it is first turn on in the morning... i do keep the oil changed regurally and the maintenance up petty good. your problem could also be the engine timing or a faulty exhaust gasket. |
change your oil and add1 lucas oil treatment.also change your filter to a purolator.worked for me.whatever you do dont use a fram filter.worst on the market.
