95 trooper
Old Nov 14, 2011 | 06:38 PM
bukied's Avatar
Cool 95 trooper
  • Hi everyone ! Just joined and was wondering if anyone had a Trooper that has high mileage on it . I have one that has 385,000 miles on it so far and it seriously runs like it is brand new. I do all maintenance myself and just changed the timing belt and sense i was in it also changed the water pump and all roller bearings . didnt need a water pump but changed it anyway. Only other things changed have been passenger side rear wheel bearing ,starter,and radiator ! No joke !!!
  • I will post some pics soon !
Old Nov 22, 2011 | 11:49 AM
iceshark's Avatar
How hard was it to replace wheel bearings
Old Nov 24, 2011 | 12:31 AM
bukied's Avatar
Default Rear wheel bearing
It was really easy . Remove top bolt from brake caliper to rotate it off of rotor. Pull Rotor off and parking brake components .there are 4 nuts that hold the assembly to the axle. They are are on the back side of the dust cove . Once the nuts are removed the whole axle and assembly will pull out. I got mine out in less than 30 min. Take to machine shop and have new bearing put on . About 15 bucks . Don't forget to replace the seal.When installing axle rotate it to line up splines and reverse process . It's that easy !
Old Jan 12, 2012 | 08:58 PM
teebear's Avatar
have you done any work on your trans. i have a 97 with over 200th on it and i just put in a rebuilt trans. its not shifting smooth now. please help!!!!!!!!!!!
whitetrooper
Apr 21, 2021 02:10 PM
89Trooper
Jun 15, 2006 03:54 PM
