bukied |
11-24-2011 12:31 AM |
Rear wheel bearing
It was really easy . Remove top bolt from brake caliper to rotate it off of rotor. Pull Rotor off and parking brake components .there are 4 nuts that hold the assembly to the axle. They are are on the back side of the dust cove . Once the nuts are removed the whole axle and assembly will pull out. I got mine out in less than 30 min. Take to machine shop and have new bearing put on . About 15 bucks . Don't forget to replace the seal.When installing axle rotate it to line up splines and reverse process . It's that easy !
