88 TROOP died today ;(
Old Apr 3, 2008 | 09:23 PM
mn840sc's Avatar
well guys the good news its nothing major i hope happend , now lets get started so i was driving low on gas and my troop suddenly just died at a stop sign it turns over and has plenty of power but wont start so i think it is the fuel filter because i ran it so low and it got cloged possibly but im no mechanic and i need your help i also tried putting some gas in to seeif that was the problem and it still didnt start thatnk you and please help if you can< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
Old Apr 5, 2008 | 04:36 AM
mn840sc's Avatar
well i changed the fuel filter today and it was pretty dam dirty inside felt a little clogged and what came out was a mix of dirty gas and black crap.....but it still didnt start when i tried so now im gonna fallow the fuel lines i guess and look and see if it has any leaks or if its getting to the injectors . if anyone can help it would be much appreciated thank you.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
Old Apr 5, 2008 | 01:32 PM
mn840sc's Avatar
well now im getting pissed i changed the spark plugs,rotor,and i am getting fuel all the way up to the fuel injection so i have no clue whats going on and it seems like this isnt the place to get answers so i dont know. IF ANYONE CAN HELP IN THE SLIGHTEST WAY PLEASE DO CAUSE THIS IS Going NO WHERE.
Old Apr 6, 2008 | 08:41 AM
glennb's Avatar
88s came with at least two types of engines and some may even have been carburated - helps to know all the specifics.....if you know you have fuel pressure at the injectors and you know you have spark (hold a plug in the air, away from danger, while someone cranks) then it should at least run rough unless there is a large vacuum leak or air intake leak - check the air intake path and all the vacuum lines
good luck
Old Apr 6, 2008 | 07:10 PM
mn840sc's Avatar
yeah sorry forgot to mention that it is the 2.6 fuel injected motor. Glenn i
did exactly that with my father yet it still did nothing. all of the vacuum lines
look all scrambled around but i checked and they looked fine maybe
something in the intake but still not sure still having problems
Old Apr 7, 2008 | 09:25 PM
mn840sc's Avatar
yup took it into the shop today and they were boggled also i have spark.fuel,and vac lines are all correct....they now are thinking it has something to do with the valve timing and are gonna take off the vaLve cover and do more research...i hope it doesnt get to expensive because from what i thought as a simple problem it is now somethng other anything would be very helpfull thx[img]smileys/smiley7.gif[/img]
Old Jun 1, 2008 | 01:10 AM
flyboy_rob's Avatar
I know it's been awhile, but have you figured out what's wrong with your Trooper, because I think that mine is doing the same thing...< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
Old Sep 12, 2008 | 04:56 PM
  #8
nqlblq's Avatar
I had the same problem on my 89 RS, turned out it was the fuel pump. And that is a real pain to replace if your trooper is a bit rusty like mine (totally rusted out to be exact).
jbrandall89
Oct 13, 2012 11:36 AM
jakerhoades89
Jun 12, 2009 05:05 AM
dtpeter
Apr 4, 2009 01:44 PM
jebx
Feb 5, 2009 11:23 AM
RodeoRaymon
Dec 28, 2007 07:38 PM
