2002 Trooper Alternator - Suggestions for removing it?
Old Jun 10, 2021 | 12:32 PM
LiefInAtlanta's Avatar
Default 2002 Trooper Alternator - Suggestions for removing it?
Haven't had much luck finding info about this while searching around. Hoping someone here can help...
I have a 2002 Trooper that has a bad alternator (causing the battery to need to be replaced as well). I've looked at various YouTube videos (none specific to this vehicle however) and read some instructions, but I cannot figure out how to get the alternator off the engine to replace it. Do I go in from the top or underneath? Is there something I need to move out of the way, or is there a trick to getting it out without disassembling everything? There are some hoses and other parts that appear to be blocking it from an easy removal. Any suggestions? Thanks in advance.
Old Jun 11, 2021 | 08:55 AM
fourwd1's Avatar
It's been awhile, but IIRC you can easily access most (maybe all) bolts from underneath.
Then it will fit through a triangular opening in the wheel well between the inner fender and frame
SMOOORESS
Jan 26, 2017 11:24 PM
Kenneth Linder
Jun 6, 2015 04:31 PM
mschott
Mar 23, 2012 10:27 AM
ajwaldrop
Mar 20, 2012 08:19 PM
