2001 2.8L Fuel Economy
Old Dec 13, 2009 | 01:30 PM
sailindon's Avatar
Default 2001 2.8L Fuel Economy
Hi All:
I have a 2001 Trooper with a 5 speed manual transmission, and a junk yard motor I installed and runs well with very limited oil usage. Tuned and timing set, changed O2 sensor, checked throttle body injectors, (fine mist when running). No check engine light, and nothing in history.
My problem is I can't get the fuel mileage over 17.5 mpg. Is this considered normal for this configuration? I don't run this vehicle hard, even on the freeways only go 65mph max.
One other point, I bought one of those ALDL cables and downloaded a free program to view the ECM, and don't see any red flags, (although I may certainly maybe missing or misunderstanding something).
I have searched the archives and could not find this discussion, sorry if I missed this.
Don
Old Dec 21, 2009 | 05:49 AM
chumpep09's Avatar
Default 2001 2 8L Fuel Economy
If you are burning twice the fuel you should be I would think the oxygen sensor would read a very rich condition and turn on the check engine light. Are you sure you are not leaking the fuel? How are you calculating your fuel economy?
bretthogg
May 10, 2011 09:56 AM
unlstorm
Apr 13, 2011 11:44 AM
///M3Augy
Jun 9, 2010 10:26 AM
hammerjoe
Jun 13, 2009 07:50 AM
