1995 trooper bogs and then stalls at wide open throttle
Old May 28, 2022 | 09:17 PM
thekitterman1221's Avatar
Unhappy 1995 trooper bogs and then stalls at wide open throttle
Trooper 1995 has been sitting for six years drove fine for awhile after I got it and then it started to gradually overtime started the bog after applying throttle would have two WOT in order to accelerate or barely navigate over a hill about a month or two after this condition revealed itself the catalytic converter caught fire so then removed catalytic converter even though I removed the catalytic converter acceleration condition did not improve but stayed the same figured screw it continue to drive it for a little bit then after complaints about my loud pipes I bridged the gap in the exhaust line from the removal of the catalytic converter and now that the muffler is attached the engine pawgs and then stalls at WOT
I have replaced idle air control valve spark plugs plug wires air filter and have also removed catalytic converter and completed the exhaust pipe where the catalytic converter should be
Positron
Oct 3, 2019 07:20 PM
msbuchanan
Mar 31, 2011 01:21 AM
pestcontrol2
Jan 27, 2009 02:29 PM
k_ogre
Jan 6, 2009 03:59 AM
