1991 trooper backfire
Old Jan 28, 2009 | 03:54 PM
peegeez's Avatar
I''ve got a 1991 trooper and in 5th gear on the freeway (60mph)under heavy load it will backfire. It drives fine under all other situations. Any ideas for this would help.
Thanks
Old Jun 11, 2009 | 09:04 PM
thegentlesoul's Avatar
Hey, for the backfiring, check your plugs to make sure that none of them are cracked. After that, check your plug wires. It could be a bad plug wire. Last but not least, check your timing, if the timing is off, it can do that as well. Hope this helps
rutang
Jan 6, 2009 02:24 AM
Campingrich
Sep 8, 2008 02:21 PM
willcuatt
May 26, 2008 10:04 PM
jerrysza
Sep 3, 2007 01:49 PM
GINAV
Apr 17, 2006 06:35 PM
