1988 Trooper II Taillight Issue
Old May 13, 2009 | 03:11 PM
ellsworth's Avatar
Default 1988 Trooper II Taillight Issue
Hey Folks,
Thanks for taking the time to read this.
I have an Isuzu Trooper 2 from 1988, the taillights won't light, but the headlights, break lights, reverse lights and every other light works fine.
I tested the fuse spot in the fuse box it has current and the fuse is good, I checked the spot where the tail light goes into and the connections do not have any power so the switch isn't sending any power to the actual tail light connection. Any help would be appreciated.
The guy at napa suggested the headlight switch, the actual thing where you pull it out to turn the headlights on, so I looked at it but I can't tell if it's burnt out or not, if this might be the problem anyone have suggestions on where to order one?
Thanks,
E
qdubu
Dec 4, 2016 10:45 AM
amcmb1968
Jun 24, 2007 08:01 PM
houptee
Jan 3, 2007 10:09 AM
graysilm
Nov 28, 2006 02:57 PM
Jim Bob
Jan 24, 2006 10:16 AM
