1988 Trooper II Taillight Issue
Hey Folks,
Thanks for taking the time to read this. I have an Isuzu Trooper 2 from 1988, the taillights won't light, but the headlights, break lights, reverse lights and every other light works fine. I tested the fuse spot in the fuse box it has current and the fuse is good, I checked the spot where the tail light goes into and the connections do not have any power so the switch isn't sending any power to the actual tail light connection. Any help would be appreciated. The guy at napa suggested the headlight switch, the actual thing where you pull it out to turn the headlights on, so I looked at it but I can't tell if it's burnt out or not, if this might be the problem anyone have suggestions on where to order one? Thanks, E |
