1988 4 cylinder won't start
Old Dec 3, 2018 | 10:58 AM
MorganRylee's Avatar
Default 1988 4 cylinder won't start
Hey guys, I looking for advice on what to check to get my trooper running again. We've replaced plugs, wires, distributor cap, mass airflow sensor, fuel pump and did a valve adjustment and it still won't start. Are there any common trooper starting issues you've experienced? It's trying to fire so the battery and starter are fine. Any help is great appreciated! Thank you
Old Dec 25, 2018 | 11:52 AM
1990's Avatar
take off the alternator and have it checked. Mine was doing the same thing and the alt. was bad. Won't run with out voltage from it. Take to a couple different shops as mine showed good at one and not the other. Replaced it and runs fine.
drdavid13
May 20, 2011 09:48 PM
kegriffinjr
Sep 3, 2009 06:14 PM
89troop1
Mar 27, 2009 01:05 AM
goingcrazy
Dec 19, 2008 11:21 AM
kreal
Nov 27, 2007 12:09 AM
