89 trooper issue help?
Old Mar 13, 2009 | 02:15 PM
89troop1's Avatar
Default 89 trooper issue help?
i got a 89 trooper 4cyl 5 speed and i have replaced spark plugs n wires and dist cap and rotor and air filter and fuel filter.. and 02 sensor and the coolant temp sensor is fine. but heres the issue i can start it when the motor is cold and it runs ok and idles ok and as long as its running its ok but if i cut it off while the motor is hott it takes forevor to start? and when it tries to it sputters when i press the gas but once i finally get it running its ok..
Old Mar 13, 2009 | 02:17 PM
89troop1's Avatar
also im replacing the alternator and whole distributor monday.. the alternator reads a little low on volts and all the warning lights come on and stay on for a while until i rev it up could it be alternator?
Old Mar 18, 2009 | 02:46 AM
bigman5956's Avatar
i seriously doubt its the alternator try changing the fuel filter it costs less and couldnt hurt
Old Mar 18, 2009 | 02:47 AM
bigman5956's Avatar
oh my bad u already changed the fuel filter might want to check timing
Old Mar 27, 2009 | 01:05 AM
Moutain_Ox's Avatar
have you noticed if your trooper is rich or lean when this happens? also dose the trooper have a thermal time switch for the ecu? these would be some good points to check. also make sure your grounds are good. an take a quick look at a spark plug. is it white an clean, or is it all black an soot covered?
paulauryn
Feb 8, 2012 07:31 PM
nguyennp
Jan 17, 2012 02:29 PM
Uticon
Mar 26, 2011 07:38 PM
isuzukids
Apr 8, 2010 01:53 PM
trooper90
Dec 1, 2006 04:49 PM
