1986 trooper fuel gauge not working
Old Jun 26, 2018 | 01:44 AM
Drake2436's Avatar
Default 1986 trooper fuel gauge not working
I recently got a 1986 trooper and emptied the old fuel out since it was sitting for a few years and my fuel gauge read empty with the fuel light on. Today I filled the tank up with about 10 gallons of gas and the fuel light went off but my gauge still ready empty. Im assuming the gauge it is bad but wanted to know what everybody thinks first as I am new to the troopers and don’t know much about them yet.
Old Feb 13, 2020 | 04:28 AM
Super Trooper's Avatar
Wow. Your fuel light works? My 1986 Trooper tells me when i first turn it on how much gas and then will show zero sometimes while driving. You have a sending unit/ float in the gas take that sends signal to the gauge. Could be as simple as a bad ground on the sending unit or gauge. Old gas could be coating the contacts on the sender or bad sender or gauge. Multi-Meters and Circuit testers are your friends. Good luck fellow troopererer.
Old Feb 14, 2020 | 03:56 PM
fourwd1's Avatar
The sending unit typically goes bad before the gauge would. IF you can get it out of the tank you might be able to clean the windings. But the bolts may be too rusted to get it out.
Shain5x
Jul 13, 2018 03:27 PM
quinnsjoblom
Jul 27, 2015 09:39 PM
sambagis
Jan 27, 2013 01:49 AM
93trooperkid
Mar 5, 2012 08:06 PM
antdhernandez
May 10, 2010 08:29 PM
