01 Trooper stalls
Old Jan 14, 2007 | 09:06 PM
Ashbypa's Avatar
OK, car has been running great but last week it
started to idle odd and then started dying. Hooked up a code reader
and get the following codes: P1120, P1290, P1275, P1280, P1285.
Usually in that order.
The APS was replaced this summer - dealer said it was shot, but I never saw the codes.
Now here's the trick - I replaced the part myself, but since I
don't have a Tech2, I couldn't set it to 10-15% per directions.
However, upon replacement the car worked fine with no codes.
The codes above are pointing more towards APS than TPS.
Anyone have any suggestions?</span>
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old Jan 15, 2007 | 01:42 AM
MASTERTECH's Avatar
you have an open in either the APS circuit to pcm or to the TPS from the pcm somtimes if you look at it with the tech 2 it will so ok but other times it reads eratic, you need to take it to a good dealer and have them look for this problem they should know about this problem from there field eng.
brianvn99
Aug 22, 2021 01:41 PM
Rob's 94 Trooper
Jun 14, 2012 02:57 PM
rander
Pickup
Dec 8, 2010 03:45 AM
slipstick
Oct 24, 2008 12:11 PM
snake0ape
IF Help & Suggestion Center
5
Dec 12, 2007 11:09 PM
