What is this? Help needed!
Old Dec 7, 2010 | 04:54 PM
01_4Banger_5Speed's Avatar
Default What is this? Help needed!
Ok,
So, were doing a clutch swap, and my helper accidentally broke the wires off this sensor. Nobody I've asked seems to know what it is exactly. I have a suspicion it's for the reverse lights, as you can feel it "switch" when you press the ball bearing end in, but I'm not completely sure. It is located towards the top of the xmission, not to far from the shifter. This is for an 01 Rodeo 2wd, 2.2L. Thanks!
Old Dec 7, 2010 | 07:15 PM
bigdreynolds's Avatar
On top section of gear box near shifter the one closest to the rear of vehicle and it should have 2 red wires(one has trace color) the blue/red switch is wrong one. Both or all 3 switches look the same/similar. depending on engine config.
location of reverse light switch on gear box
Hope this helps .
Old Dec 7, 2010 | 07:33 PM
Yea. It's definitely the reverse light switch. I previously posted that I had found it, but for some reason it isn't showing.
Thanks for your reply, however! I really appreciate it!
moochymoo
Sep 12, 2007 07:28 AM
princess
Pickup
4
Feb 1, 2007 04:03 PM
princess
Dec 17, 2006 02:26 PM
trooper90
Dec 1, 2006 04:49 PM
OSUspe
Aug 29, 2006 10:44 PM
