Transmission fluid
Old Dec 2, 2010 | 07:56 PM
abeninger's Avatar
Default Transmission fluid
So, I have a 2001 Honda Passport, which is the same as an Isuzu Rodeo right? I was wondering if you can use Honda atf-z1 trans fluid in place of dexron without any problems?
Thanks!
Old Dec 6, 2010 | 04:49 AM
wizard2406's Avatar
only use what the manual that came with your passport.. You have to be really careful what you put in your transmission.. People are know to have alot of problems with these cheap transmission.... even kill them around 80,000 miles on the car.
Old Dec 7, 2010 | 06:32 PM
abeninger's Avatar
Well, that's the thing. I may have had a mechanic put in the wrong fluid. He put in ATF Z1 and i'm not sure if it's screwed up my trans. Isuzu flat out refuses to answer the question if that Z1 stuff works in the trans.
tractng
Sep 27, 2010 01:06 PM
AmigoMan
Dec 17, 2007 04:51 PM
Annihilator
Nov 15, 2007 02:34 PM
jleland
Feb 3, 2007 11:52 PM
robdog
Mar 25, 2006 12:31 AM
