Problem with turn signal and reverse lights
Old Sep 25, 2010 | 11:41 AM
Jigpitcher's Avatar
Default Problem with turn signal and reverse lights
Hi folks,
I have a frustrating problem with a '92 Rodeo that I just purchased for my son. The right turn signal will not function, nor will the reverse lights. The bulbs are good in the front (turn signal) and I have switched the light units in the back as a test and the turn signal works fine when it's on the left side (hope this makes sense!).
Re the reverse lights, they just don't work. I found the 10A fuse on the dash fuse panel and it looks fine.
Can the "sealed" rear light units be somehow "unsealed" so I can see if the reverse light bulbs are bad?
As I'm sure is painfully obvious, any suggestions would be appreciated!
jimgreene
Sep 28, 2014 06:46 PM
sidepocketsuz
Apr 18, 2012 04:14 PM
Trooperguy
Aug 28, 2007 07:35 AM
princess
Dec 17, 2006 02:26 PM
