OIL Guage and Dummy light not working
Hello all!
I purchased a 91 rodeo 3.1 4X earlier this month and have been working diligently to get it on the road.
i have finally completed all my work but when i start the truck the Oil guage reads zero and the oil pressure dummy light comes on.
First question: i was welding a new nut onto the oil tank to replace the stripped oil plug that was on it. could i have fried the oil sending unit?( i know its just a variable resistor but ???)
Second question: is the dummy light sensor in the oil sending unit or is it a seperate sensor? (if they are seperate sensors then that would lead me to believe i trully have no oil pressure).
Third question: Where can i find a cheap oil sending unit? i looked on rock auto and found one for $47(not bad) but locally they want $147 for one.
thanks.
>>>>>>>Work completed<<<<<<<
-driver/passenger inner outer tie rod ends with new tie rods
-New sway bar linkages
-New door hinges driver/passenger
-rew rear axle bearings and seals
-rear brake cylinders
-new idler arm mount
-still dont know what is wrong with 4x4 BUT ONE HUB ASSEMBLY IS GUTTED
Edited by: lukera
SpadesOfIndia
Mar 23, 2009 09:43 AM
awnicol25
Aug 25, 2006 11:03 AM
