Hello all! I purchased a 91 rodeo 3.1 4X earlier this month and have been working diligently to get it on the road. i have finally completed all my work but when i start the truck the Oil guage reads zero and the oil pressure dummy light comes on. First question: i was welding a new nut onto the oil tank to replace the stripped oil plug that was on it. could i have fried the oil sending unit?( i know its just a variable resistor but ???) Second question: is the dummy light sensor in the oil sending unit or is it a seperate sensor? (if they are seperate sensors then that would lead me to believe i trully have no oil pressure). Third question: Where can i find a cheap oil sending unit? i looked on rock auto and found one for $47(not bad) but locally they want $147 for one. thanks. >>>>>>>Work completed<<<<<<< -driver/passenger inner outer tie rod ends with new tie rods -New sway bar linkages -New door hinges driver/passenger -rew rear axle bearings and seals -rear brake cylinders -new idler arm mount -still dont know what is wrong with 4x4 BUT ONE HUB ASSEMBLY IS GUTTED :(Edited by: lukera |
well thanks for all the help. as it turns out it was a dirty sensor...i removed it, wiped it down and now all is fine...with that anyway. |
