new to the rodeo
Old Oct 2, 2007 | 07:05 PM
ohiorodeo's Avatar
Hello,
Iam new to the rodeo. I just bought a 1994 rodeo with 184,000 miles on it and I wanted to know what items I should check outfirst. Iam going to change the oil. What fluids do the front and rear axles take and trans and the transfer case. Please help me all you can. I have never owned a isuzu.
ThanksEdited by: ohiorodeo
Old Oct 2, 2007 | 07:32 PM
Front and rear diffs use GL-5 gear oil. If yours has limited slip rear differential (look for the code G80 on the options plate on the firewall) then you will also need to add 1.5-2 tubes of limited slip addative to the rear. Transmission and t-case use 5w30 engine oil though I prefer to use a 5w30 MTF oil. Its made to be used in transmissions and shifts much smoother with it. I use Amsoil MTF and it works great. Redline and pennzoil also make 5w30 MTF.
Old Oct 2, 2007 | 07:34 PM
ohiorodeo's Avatar
thank you very much.
Is there any other things I should check?Edited by: ohiorodeo
Old Oct 2, 2007 | 07:35 PM
ohiorodeo's Avatar
How about the frame, alot of people say there are junk?
jsge090
Mar 15, 2015 12:15 PM
Wolfcri
Apr 1, 2009 05:41 PM
Mungoon
Aug 23, 2007 09:40 PM
Inferno
Apr 20, 2006 10:02 PM
