Misfiring and shutting off when it reaches running temp
Old Feb 2, 2019 | 03:02 PM
ZuZuRider's Avatar
Default Misfiring and shutting off when it reaches running temp
I have a 2004 Isuzu Rodeo 3.2l. For about a week I noticed at 1st start up it would rev high and then go to normal. After about a week I went to start it, it started but started to run a little rough. I went to drive it the other day and after about 1 mile down the road it shut off while driving.....wouldnt start back up for about 20-30 minutes. Then did it again. Their was a code for intake gaskets but those were checked and fine. Good fuel pressure, checked coils and now have no clue. Anyone have this problem or know what else to check out? Mass air flow sensor and temp sensor are good too.
Old Mar 29, 2019 | 11:44 PM
97rodeo97's Avatar
Start the engine open the hood and spray little squirts of brake clean near the intake gastket, near the manifold around vacuum lines and connections if the engine sounds like its changed rpms or smoothed out you have found the leak. You can also use an unlit butane torch instead of brake clean
jabartman
Nov 2, 2015 03:11 AM
dan5505
Nov 22, 2012 07:00 PM
KDemarest7725
Aug 25, 2010 10:10 AM
lexluther
Oct 6, 2009 01:38 PM
cmaaann
Pickup
4
Jan 26, 2008 04:01 PM
