Lifters
Old Jul 16, 2009 | 06:55 PM
96isu's Avatar
Default Lifters
I have a 96 isuzu rodeo 3.2l 4wd and the engine is ticking and i heard it was a common problem for these engines and wanted to see if there was some way to fix this problem
Old Jul 19, 2009 | 12:32 AM
jamnjm's Avatar
Question
V6 I take it?
How many miles on it?
How offen with oil changes? What does the oil look like? Metal / metallic floating in it?
Have you change the timing belt & guides yet?
Old Jul 19, 2009 | 06:26 PM
security11122's Avatar
I have a 98 1/2 with 200k on it and the ticking is there after about 500 miles after a oil change, I have been told that the valves need adjustment. Mine isn't too loud and only really hear it if your outside or the windows are down while driving. so i don't really worry about it.
Old Jul 23, 2009 | 03:34 PM
96isu's Avatar
it is a v6 right now it has 196k miles on it and i give i oil changes every 3000 miles the oil looks clean with no flakes in it
Old Jul 23, 2009 | 09:06 PM
jamnjm's Avatar
Question
What weight oil?
Old Jul 24, 2009 | 06:59 AM
I use 5 w 30 during the winter and 10 w 30 summer, It gets really hot during the summer. I heard that 15w 40 would make the sound worst, I haven't tried that yet though. I was using systhic but don't find any real advantage with these engines so i buy the highest quality convention for the money I hope. Mobol 1 5000 works well for me and drans light brown after a 3000 mile oil change.
201500 miles on truck
Old Jul 24, 2009 | 10:58 PM
96isu's Avatar
I use 10w30 castrol syntec oil
Old Aug 4, 2009 | 02:15 PM
  #8
Doug I's Avatar
yup our 97 ticks - sometimes.
Fire it up - ticks - count to 5 and it stops. Lifter for sure. Problem ? nope.
If it ticks longer check oil level.
One trick I've heard is to fill it with 5W mystery oil. Run it for 30 seconds and drain. Repeat 2 or 3 times. I've been told that'll flush all sorts of crud out.
marc9976
Apr 30, 2008 09:18 AM
Azathoth
Jan 5, 2008 12:22 PM
bbusbee
Apr 1, 2007 06:15 PM
jwn1984
Feb 15, 2007 08:47 PM
sandyb23
Nov 11, 2005 04:16 PM
