lift kit for a 2002 rodeo LS
Old Jun 1, 2008 | 11:31 PM
buckethead's Avatar
I just got my rodeo and i want to lift it. i cant find a single lift kit for this truck online. does any one here know where i can get at least a 3" lift?< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
Old Jun 2, 2008 | 06:26 PM
3" is all you are going to get out of the suspension for a lift unless you do a SAS. The best place to get the parts for a lift is from independent4x. Matt is great with customer service and drives isuzus himself so is very knowledgeable if you have a problem. Calmini also makes a lift kit but includes alot of parts you dont need, costs more money, and their customer service is almost non existent.
One problem with doing a lift on an '02 is that at some point that year isuzu went to the GM style "large nut" front hubs with sealed bearings and you cannot put manual locking hubs on them. Everything will still work fine but with 2nd gen rodeos they have drive flanges instead of auto/manual hubs so the cv shafts are always turning, even in 2wd. The increased angle from a lift will wear out the cv boots sooner. Just check them occasionally.
Old Jun 12, 2008 | 07:41 PM
RyJen's Avatar
But can you change the hubs from an 02+ to the older style in order to put the manual hubs on? Edited by: RyJen
Old Jun 12, 2008 | 11:39 PM
As far as I know you can. Probably wont be cheap though, I think you need the whole knuckle, brakes, and cv axles but I''m not sure. I dont know of anyone that has done it yet.
SuzieQ
Nov 11, 2011 11:47 PM
usaafguy1
IF Help & Suggestion Center
Mar 17, 2011 11:50 PM
Amigo Mike
Feb 21, 2010 11:08 PM
ericrodeo
May 17, 2008 02:35 AM
AXEFFECT
Suspension
Jan 16, 2008 12:41 AM
