Just bought
Old Oct 31, 2007 | 09:46 PM
Jags87's Avatar
Hey whats up iam new to the forums. I was jsut givin a 95 Rodeo and i drive K5 blazers and such that are lifted. I dont know much about Rodeos so iam in need of some advice. Where can i find a good suspension lift kit should i go with that or a body lift kit i want clearance. I have been looking around here in az but not finding anything anywhere if anyone could point me in the right direction that would be nice thanks guys
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old Nov 1, 2007 | 05:55 AM
XR400R's Avatar
Hey, welcome Jags, &amp; good luck with your '95!
I have not done it, mind you, butmany Rodeo/Passport owners seem to favor the Calimini kits to get a 3" suspension lift. Go here to see:
http://www.pureisuzu.com/isuzumain.htm
It's a bit pricey, but apparently high quality &amp; well designed. The main thing you need to watch out for is your CV joints when you increase the CV bend angle with a lift. It helps to put manual hubs on your baby (if you don't already have them) so the joints are not turning even when you are in 2WD. I have done that &amp; it's really easy. Also helps slightly on mpg &amp; helps the CV's last longer.
Another one that appears to be very popular among the hard-core off-roaders is the Indy4X kits:
http://www.independent4x.com/homepage.html
Best of luck, &amp; let us know what you do, &amp; how it goes!Edited by: XR400R
Old Nov 1, 2007 | 03:57 PM
Jags87's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
thanks for you help ill check into them today. when i get it done ill get pics up hopefully i get it done by december.
turbine
Impulse
7
May 2, 2007 06:01 PM
lancet06
Jan 12, 2007 12:54 PM
kb2nto
Dec 21, 2006 11:18 PM
99zubabyhauler
Mar 17, 2006 02:04 PM
drew
May 5, 2005 09:42 PM
