high idle
Old Mar 24, 2006 | 10:57 AM
t429258's Avatar
&lt; =&gt; <!--
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
//--></>i have a little problem with my idle. it has been creeping higher and higher for the last week or so. from reading on here i think it may be a vacume leek. how do i finde where it is thow the engine sounds like a pig geting it guts ripped out. the air filter is loud and i can hardly hear over the 2 1/2 rpm idle any way. and it will idle at about 1 rpm in drive or reverse
so is ther any kind of stupid proof way that i can use and if so please explane it to me i am prity slow[img]smileys/smiley5.gif[/img] thanks a lot guys
99 rodeo v6 4x4 auto
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
</>Edited by: t429258
Old Mar 24, 2006 | 02:43 PM
It could be a broken intake manifold gasket. I'm not sure if that would cause it to idle high, but I know '99s are prone to the gaskets (actually its plastic) breaking.
You can try spraying areas you suspect of having a leak with carb cleaner or wd-40. If there is a leak you should hear the idle change.
dan5505
Nov 22, 2012 07:00 PM
alphatabs
Jul 5, 2011 04:07 PM
wasim
Dec 2, 2010 05:21 AM
lucky guy
Oct 3, 2009 01:10 PM
tudman70
Dec 10, 2007 09:17 PM
