Help! 2009 Rodeo 3l
Old Aug 21, 2025 | 09:21 PM
situp&squeeze's Avatar
Unhappy Help! 2009 Rodeo 3l
Hi there, can anyone help me? Any suggestions are appreciated.
I have a 2009 Rodeo 3l. Since owning it the engine light has come on intermittently, sometimes it would go into limp mode, usually after stop starting a few time the light would go off on its own, or the garage would change the fuel filter and that used to do the trick for a while. The code came up saying there was an issue with the fuelling system.
After this years service, the light came back on and has not gone off but the bugger is in limp mode.
The garage suggested removing the egr & dbf, then remapping but that made no difference to it. The light came back on.
They have cleaned and then replaced the sending valve, nothing changed.
The new filter is full of crap already, so they suggested changing the fuel tank. This hasn't made a difference.
Have any of you had this issue?
than you for your time!
mooseye
May 29, 2012 03:41 PM
jasper
May 15, 2012 01:40 PM
isuzugirl
Oct 30, 2009 11:14 AM
lexluther
Oct 6, 2009 01:38 PM
ih8civx
Jan 23, 2007 06:56 PM
