Rodeo misfire off idle
Old May 27, 2012 | 09:39 AM
mooseye's Avatar
Default Rodeo misfire off idle
This problem started a year ago.
The rodeo started to sputter and miss when taking off from a stop. It has gotten worse to the point that you can't drive it.
I changed the plugs and wires yesterday and it seemed to have gotten worse. The plugs looked very bad but were all not fouled.
I sprayed gas into the intake hose and it would accelerate fine as long as I sprayed fuel into the hose while opening the throttle.
It is getting plenty of fuel to the hose at the engine end.
Filter is free flowing and pump is working.
It will idle fine but rough and almost no acceleration.
Before it got real bad it would run okay with wot and most times with part throttle but engine light would come on and begin to run rough but if I let off gas pedal light would go out and run smoothly again.
Since the light goes back out when you let off gas it doesn't set a code.
Help Please!
Old May 29, 2012 | 03:41 PM
mooseye's Avatar
Default hmm
I guess this forum is not very active?
JohnJoseph
Mar 12, 2011 12:54 PM
dcsportej1civic
Aug 19, 2010 10:58 PM
Big Al
Jul 17, 2010 05:59 AM
Big Al
Mar 22, 2010 09:45 PM
fishgauthier
Jul 10, 2008 10:33 AM
