flashing check engine
Old Nov 14, 2007 | 09:02 PM
jetmech09's Avatar
2001 Rodeo V6 check engine light is flashing, engine runs fine. what can this mean?[img]smileys/smiley5.gif[/img]
Old Nov 17, 2007 | 10:02 PM
You should never drive it with a flashing CEL. That means something really bad is happening. You need to get the codes read though before we can help you. Need to know exactly what the code is so we know what is causing it. Autozone will read codes for free.
Old Nov 18, 2007 | 07:56 PM
jetmech09's Avatar
code is 401 egr insuff flow
Old Nov 18, 2007 | 10:16 PM
You need to clean the egr valve and the tube for it that goes inside the intake manifold. Info how to do it in the link below.
http://isuzufaq.ibctech.ca/#faq1
Old Nov 18, 2007 | 11:23 PM
jetmech09's Avatar
Hey thanks for the info I will do just that, will post results. thanks again!![img]smileys/smiley1.gif[/img]
Old Nov 21, 2007 | 01:48 PM
jetmech09's Avatar
removed EGR valve and cleaned exhaust port and vacume ports. did notice valve sticking closed. cleaned out valve and reinstalled. so far so good,no light!! Thanks again for the info.[img]smileys/smiley4.gif[/img]
Old Nov 21, 2007 | 08:54 PM
Glad it worked out[img]smileys/smiley1.gif[/img]
rmac
Mar 14, 2021 03:50 AM
zerinephalis
Jun 25, 2016 02:29 AM
Cornboats
Pickup
Sep 10, 2011 04:58 AM
Dragunb
Feb 9, 2008 07:25 PM
sicilian68
Jan 16, 2008 05:20 PM
