Engine Replacement
Old Mar 1, 2006 | 07:42 PM
partime's Avatar
Hi! I have a 2001 Rodeo with a bad (3.2) engine. What years or models will fit? I also heard the 3.5 will fit by taking intake and other parts off and replacing with the ones off the 3.2? Any help out there? Thanks!!! Partime
Old Mar 2, 2006 | 01:47 PM
Any of the 3.2 engines from '98 on (DOHC) will be the same. I dont know about using the 3.5 block to replace the 3.2, I dont think I have heard of anyone doing it yet.
Old Jun 5, 2006 | 02:31 PM
hannamet's Avatar
Hi guys, this is exactly what I need to do; replace my 3.2 with the 3.5 block. Someone must know if it will fit!?! Filters and all are athe same, I'm thinking Isuzu simply used bigger bores in the 3.2? I know the flywheels in the 3.5 take a bigger clutch. HELP! BD
Old Jun 7, 2006 | 03:24 PM
PIGS's Avatar
I wish I knew, but let me know if you find out. My 99 is burning oil bad. Still waiting to find out if the Nissan Dealership I bought it from is going to honor thier used car warranty.
Old Jun 7, 2006 | 03:49 PM
hannamet's Avatar
Jeryy says all is good. The 3.5will bolt in to replace the 3.2. Use the 3.2 intake manifold to maintain throttle linkage if they are different.I'm gonna try it soon myself. BD
Old Jun 7, 2006 | 05:59 PM
ISUZUGURU's Avatar
Super Moderator
the crankshaft is different in the 3.5 an rod length,gives it a longer stroke.theres not much of a power difference from the 3.2l.everything would bolt up perfect except for the pcm.since the crank position sensor reluctor wheel is different from the 3.2 pcm it wouldnt start.isuzu didnt fix the oil burning concern until 2003 production engines,so if you buy a new engine now it would be updated already,long or short blocks.we seel them iat my dealership for around 4700 long block 3000 short blocks.for the hassel an the little power gain its not worth the trouble an money spent.Edited by: ISUZUGURU
mananambal
Oct 27, 2011 07:02 PM
B20hatch
Aug 5, 2009 09:10 AM
Dennis
Oct 15, 2007 10:10 AM
Topherhales
Dec 11, 2006 11:26 PM
