clutch replacement
Old Jan 20, 2007 | 09:26 PM
coastal's Avatar
I am replacing the clutch in my 95' rodeo and the transfer case will not pull back more than 3/8" . All the bolts are out I am sure, It's a manual transmission and according to the haynes manual it says to take the tranfer case off seperate from the transmission . Suggestions would be greatly appreciated Thanks, Steve
Old Jan 25, 2007 | 12:11 AM
MASTERTECH's Avatar
NO that trans is one assembly, take it out as an assembly, its heavy
Old Jan 26, 2007 | 10:11 PM
ISUZUGURU's Avatar
Super Moderator
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
master tech is right take it out as an assembly.that trans doest seperate the transfer case is intergrated with the transmission.[img]smileys/smiley3.gif[/img]
bandit3135
Jul 31, 2023 01:34 PM
bbusbee
Nov 15, 2012 01:49 AM
DJ_Rob_E
Nov 12, 2008 12:05 PM
partime
Jun 7, 2006 05:59 PM
schonrph
Jul 13, 2005 12:42 PM
