Check Ingine Light
Old Feb 14, 2008 | 03:40 PM
RebeccaT's Avatar
I have my check engine light on and I went to Auto Zone and got these 3 codes.
p1404, p0155, po0154. something to do with the egl. what should i do about this to get my light back off and fix the problem.
_uacct = "UA-939292-44";
Old Feb 14, 2008 | 09:49 PM
P1404 - EGR valve stuck closed.
Probably clogged with carbon. The valve and the tube that goes inside the intake manifold probably need cleaned.
http://isuzufaq.ibctech.ca/#faq1
P0154 - o2 circuit no activity detected (bank 2 sensor 1)
P0155 - 02 heater circuit (bank 2 sensor 1)
Either a bad sensor (bank 2 is drivers side, sensor one is before cat converter) or a problem with the plug for it.
Old Feb 19, 2008 | 07:10 PM
Kreedhermione's Avatar
My check engine light has been on since the second week I got the Rodeo. I have a 2000. It has been inspected, looked over, given a cavity search, but there is no problem that anyone can find. It still drives fine and everything seems to work ok. The mechanics just tell me that it's a fluke. < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
sammie white
Sep 29, 2011 10:50 AM
yhata
Jun 5, 2010 03:23 PM
collyswamper
IF Help & Suggestion Center
Mar 22, 2008 11:27 AM
nwtraveler469
Feb 22, 2008 08:10 AM
derek44
Nov 25, 2006 03:38 AM
