Check engine light
Old Jan 8, 2009 | 09:51 AM
verludi's Avatar
Thecheck enginelightis on, does anyone might know what the problem could possibly be, because I donīt have the owners manual.
isuzu rodeo 2003
Old Jan 8, 2009 | 11:22 AM
brynnespot's Avatar
The first thing you need to do is buythe owners manual for your rig.... it''s not that hard to find and they are veryinexpensive.
Your post is too general. It really doesn''t sound like anything is wrong.. is the car actually not running properly? It could just be a sensor. Thereare handfuls beyond handfuls of information out there, take the time and do the research. I''ve already found a good amount of answers to problems my rig has just by looking around.
Old Jan 9, 2009 | 07:27 PM
Find someone that can check the codes from the ECU. Dont know about costa rica, here we can go to auto zone auto parts store and they will do it free. Have to know what codes it says before even guessing at what is causing it.
Old Jan 28, 2009 | 05:13 PM
security111's Avatar
My check engine light is on also, but the engine runs very well and i am still getting about 24 miles per gal. It relate to the emissions system, like a ox censer. I have 200,000 on my engine.
Old Jan 31, 2009 | 04:52 PM
vebontrager's Avatar
To add on to whatsomeone else briefly mentioned about checking codes. Go to Any auto parts store and spend 150 $ and buy your own code reader and you can check your own codes. This is good because some auto shops charge to do this and you can do it from home. Just be aware that some mechanical knwledge is nescesary to read the codes and to know the right course of corrective maintnance. Edited by: vebontrager
Old Feb 2, 2009 | 09:35 PM
GRodeo2000's Avatar
It could be anything. Mine once came on when the spark plugs were wet.
Old Feb 7, 2009 | 11:12 PM
evanscott's Avatar
Did you make sure you turned your cap to your gas tank
all the way? This always happens to me if I don''t make
sure I turn it at least 3 clicks.
ish
IF Help & Suggestion Center
Jun 13, 2013 06:42 AM
sammie white
Sep 29, 2011 10:50 AM
collyswamper
Mar 22, 2008 11:27 AM
gimmneycricket
Mar 11, 2007 10:39 PM
RODEHO
Mar 7, 2005 12:29 PM
