'99 Rodeo LSE Automatic Trans buzzing
Old Mar 17, 2011 | 11:43 AM
KUROK's Avatar
Default '99 Rodeo LSE Automatic Trans buzzing
Hi all,
I'm new here and I need some advice.
My '99 Rodeo LSE 2WD has been a great truck all these years.
I only have 116K miles on it and have taken really good care of it.
Unfortunately, there is a buzz or whine sound in the transmission when the RPM goes above 2000 to 2500 RPM. If everything is warm and I stop and get out (like a quick trip to the drug store) the noise isn't so bad afterwards. Weird! This has been going on for quite a while now with no effect on performance until today. It seems to have a little hesitation at shifting as in the RPM will surge a bit.
A mechanic listened to it and since he could hear it when in Park or Neutral he ruled out the Planetary gears. He believes it's in the power converter pump...like a hairline crack or something.
Anyway, has anyone had this issue and if so what was the fix?
Can this be repaired or will a rebuilt transmission be the answer?
Thanks in advance for your help...
Vince
Old Jul 18, 2011 | 09:18 PM
KUROK's Avatar
Trans failed on a family trip to fla. Got it rebuilt. Torque converter was bad. Pump was ok. I had the fluid replaced back at eighty thousand but I should have cleaned it more often. Only towed once with it. Might have been city driving....
Chiadrum
Apr 5, 2019 11:33 PM
Lippa007
Apr 5, 2012 11:23 PM
SFG
Jun 7, 2010 12:24 AM
carlover626
Jan 20, 2007 05:04 PM
sugarbob
IF Help & Suggestion Center
Jan 26, 2006 10:49 AM
